Ford Fiesta ST Gr. N
- seppo
Mielenkiintoinen peli, Mahtooko olla Civicille ja Cliolle haastajaksi?? Ainakaan mainittu hinta ei päätä huimaa (n. 30.000.- ¤ valmiiksi tehtynä)
Aihion voi ostaa paikalliselta diileriltä ja osapaketin M-sportilta.
Lähde: Rally-live, ohessa alkuperäisesta jutusta oleelliset:
Under the leadership of M-Sport engineer Chris Williams, the team at M-Sport took the standard road car back to a bare shell. Using the technology employed in the development of the Ford Focus RS World Rally Car, they rebuilt the Fiesta to incorporate the safety features and the performance improvements required for it to compete successfully on rallies around the world.
"The brief to our engineers was simple," said Wilson. "I asked them to design a car that was fun to drive but with cutting edge performance. We wanted to revisit the days when an enthusiastic amateur driver could take a standard car from a Ford dealer and use the parts kit supplied to build a competition car that was fun to drive, reliable and economical to compete in. I've tested the car and I believe it stands up to all those requirements.
"The Fiesta ST Group N is a vehicle which will appeal to drivers at all levels of the sport. It is aimed at everyone from young competitors just starting out at the grass roots of rallying, right up the ladder to drivers wishing to sample the excitement of competition at professional level. If you are a rally enthusiast, the Fiesta ST Group N is a car that you will want to drive," he added.
A ready-to-rally car will cost in the region of 30,000 Euros, including the cost of the standard road car, and the Group N conversion kit can be bought from M-Sport. Future plans for the car include a one-make series in several European countries.
Ford Fiesta ST Group N - Technical Specification
Engine
1999cc Duratec engine. Four cylinders in line, DOHC, 16 valves, alloy cylinder head and block. Electronic multipoint fuel injection.
Power
165PS at 5800rpm
Torque
202Nm at 4500rpm
Transmission
Five-speed 'dog' engagement gearkit fitted to standard ST road car casing. Upgraded driveshafts fitted as standard. Plated LSD.
Suspension
Upgraded suspension of ST road car includes revised front knuckles and strengthened twist beam rear axle. Reiger dampers, adjustable for rebound, and revised spring rates. Uprated suspension bushes.
Brakes
Standard ST road car front and rear disc brakes.
Wheels
Gravel: 15in OZ Racing wheels
Asphalt: 17in OZ Racing wheels
Wheels manufactured in both Super T and Rally Racing style.
Bodyshell
Multipoint roll cage designed by M-Sport, complying with FIA regulations. Includes three X braces in rear and twin tube door bars with no cross-over.
Electronics
'Piggy back' loom supplements standard loom. Includes electronic circuit breaker and wiring for additional requirements.
Fuel tank
Standard 45-litre tank with Kevlar composite moulded guard.
Dimensions
Length: 3921mm. Width: 1683mm. Height: 1468mm. Wheelbase: 2486mm.
Engine
Power
165PS at 5800rpm
Torque
202Nm at 4500rpm
Transmission
Suspension
Brakes
Wheels
Bodyshell
Electronics
Fuel tank
Dimensions
- Mizka
Taitaa valitettavasti olla altavastaajana teho/painosuhteen takia. Esim. Clio Ragnottista irtoaa reilu 190 kaakkia puhumattakaan Japan spec-Civicin n. 240 hv. Auto itessään siviiliversiona on tosi miellyttävä ajoltaan, tosin voiman puute on siinäkin havaittavissa.
Henk. koht. vanhana foordiharrastajana toivois Fiestasta kilpailukykyistä kinneriä haastamaan ns. valtamerkit
, hinnan puolesta saattaisi tavoittaa kiinnostuneita (maksukykyisiä) kuljettajia. Itse en heihin kuulu...
- Rallisatiainen
- TienTukko
- Unto
Autohan on ollut jo kauan tuotannossa, mutta jostain syystä vasta hiljattain luokiteltu! Voin olla myös väärässä!seppo kirjoitti:Kappas... taisin olla väärässä. Onko kenties kyse sitten siitä mitä osia siihen on luokiteltu?? Joku "järkevä" selitys täytyy olla siihen ettei niitä ole kisoissa näkynyt?
- MS-MOTORSPORT
- tja
Pösössä kun sattuu olemaan 206 mallissa takana vääntösauvajousitus joka hieman (jopa liikaakin)teettää töitä ennenkuin auto on kohtuullinen ajettava. Sitten on vielä ne alatukivarret hmm. ei ole edes lähellekkään vastaavan järeet ja tukevat kuin 306 s16. Tosta pösön takajousituksesta on jonniinverta kokemuksia ja on kyllä parempiakin vaihtoehtoja.
- PK1961
Juu,ihan näyttäis olevan S1600 pösö,jollaisella esim. Jussi WRC03 ajeli jo aikoja sitten MM-sarjaa.Ylläolevassa keskustelussa kai puhuttii Gr N 206:sta.ralli-hemmo kirjoitti:http://www.aronssonrally.com/
Näillä pojilla on 206 käytössä ihan rallipuolella.
- SJJ
Kyseisellä Fiestalla ajetaan "Ford Flexifuel Cup" elikkä merkki luokka.
http://www.fordteamrs.se/cup.htm
autot ajetaan etanolilla.
- Makemyday
Juttelin muutaman Fordin tyypin kanssa ja ne lupasivat ensi vuodeksi yli 30 kaakkia lisää, kun pakosarjan saa oikaista, nyt siinä on kuulemma aika tiukka mutka. :oRallisatiainen kirjoitti:Minäkin yllätyin, että tuosta 150 hv myllystä ei ole otettu kuin tuo 165 hummaa vaikka käsittääkseni potentiaalia olisi. Oletin liikuttavan jossain Clion lukemissa.Mizka kirjoitti:Taitaa valitettavasti olla altavastaajana teho/painosuhteen takia.
- jarko
Unto kirjoitti:Autohan on ollut jo kauan tuotannossa, mutta jostain syystä vasta hiljattain luokiteltu! Voin olla myös väärässä!seppo kirjoitti:Kappas... taisin olla väärässä. Onko kenties kyse sitten siitä mitä osia siihen on luokiteltu?? Joku "järkevä" selitys täytyy olla siihen ettei niitä ole kisoissa näkynyt?
Auto on luokiteltu ja siihen saa mitä tahansa hilkkeitä. Siis löytyy laatikot, lukot, jarrukamppeet yms. Hinnoista en tiedä, mutta luokkareista löytyy kaikki tarvittava. Luultavasti auton ongelmat piilevät (takapään) jousituksessa. Rallicrossissa 205 RC on suosittu ja menestykseläs malli.
